mickyfin32 Posted January 18, 2008 Share Posted January 18, 2008 here are a few pics can anyone tell me where they go and what they are and in some case how to fix them the pics will explain the rest. this is by the steering coloum it connect to a yellow plug which is attached to the loom ie its something that attaches to loom but what???? is a mystery to me these wires are leading up the driverside pillar i think they are to do with clock and interior light how do i connect these to loom do they attach on to the loom or??? what is this and where does it go? and what is the yellow wire coming off it for?? these 2 are the same thing i think its the heated windscreen relay and old loom was ripped out when i had the car also there is a standar windscreen in the car so this is why i think anyhelp would be so greatfully recieve as you see i have a challenge ahead of me to sort out these electric problem well i got engine problem but thats for another post another day thanks guys/gals Link to comment Share on other sites More sharing options...
mickyfin32 Posted January 18, 2008 Author Share Posted January 18, 2008 (edited) ok this looks like power roof loom these are the clock wires and do attach to the main loom this is the rear power roof realys and they usually both green relays ok this is the heated front screen loom and if you have a standard non heated screen in car this can be removed hope these help sorry to be a pain how are the interior light and clock attached which part of the loom or is it ment to be built up on the loom. i have 2 green relays in the back of the car by the pump with a silver fuse there, and what is the yellow wire coming off. and the roof loom is seperate from the main loom and its was never removed so not sure what i'm ment to do with it and this is abit further down that same wire i circled the bits i have no idea where or they attach to be greatfull for abit more input maybe some examples illustrations i looked in haynes come up blank, thanks Edited January 18, 2008 by mickyfin32 Link to comment Share on other sites More sharing options...
mickyfin32 Posted January 19, 2008 Author Share Posted January 19, 2008 ok clock wires should be hard wired into loom the two relays is the front part of the roof loom and would normally be placed under dash with rest of relays black and yellow wire attaches to loom and yellow wire goes to roof switch ok the yellow bit also belongs to the roof loom and plugs into main loom will get some pics of roof loom and connections tomorrow if i got a loom here if not it will be monday before i can get them hope this helps Thanks i am greatfull for the feed back and the pictures of the roof loom connectsion would be a big help when you are able to get them, i do have a few other questions but i will leave them intil i look at the pic and sort out the room loom then i can sort out in which i will most problt be bugging u for answers again lol cheers mate. Link to comment Share on other sites More sharing options...
