Guest MR G Posted January 15, 2008 Share Posted January 15, 2008 Hi guys, Been trying to search to see if there is a way around this, but when I shut my car door, the window doesn't go under the outer seal, but rather on top of it, I have to literally slam the door by the glass also to make it shut. It's almost as if the seal is too stiff, the hood is very new apparently. However, I was searching on the forum before posting, and apparently you can adjust the windows so they don't go quite so high, I am not sure this is what I need to do, but I only need maybe 2mm adjustment for all to be well Sorry for so many questions straight away Mike Link to comment Share on other sites More sharing options...
Admin Ollie Posted January 15, 2008 Admin Share Posted January 15, 2008 Hi guys, Been trying to search to see if there is a way around this, but when I shut my car door, the window doesn't go under the outer seal, but rather on top of it, I have to literally slam the door by the glass also to make it shut. It's almost as if the seal is too stiff, the hood is very new apparently. However, I was searching on the forum before posting, and apparently you can adjust the windows so they don't go quite so high, I am not sure this is what I need to do, but I only need maybe 2mm adjustment for all to be well Sorry for so many questions straight away Mike hi mr g if you take your door panel off there is a 10mm bolt that adjusts your window up or down easy enough to find as it has a slot for movement ollie Link to comment Share on other sites More sharing options...
Guest sjc Posted January 15, 2008 Share Posted January 15, 2008 theres a desciption in haynes for this....you can access the manual on the net Link to comment Share on other sites More sharing options...
Guest MR G Posted January 15, 2008 Share Posted January 15, 2008 get some neat washing up liquid on the outer rubber open and close door a few times to soften it up mate Brilliant, I will give that a try as the seal is pretty stiff hi mr g if you take your door panel off there is a 10mm bolt that adjusts your window up or down easy enough to find as it has a slot for movement ollie Great thanks! Will give that a try, pop off the doorcard and wind it down slightly on both sides. theres a desciption in haynes for this....you can access the manual on the net Thanks, I have just brought a Haynes so will look it up Cheers everybody Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted January 16, 2008 Share Posted January 16, 2008 i've got the same problem on my mk4, took door trim off, but the bolt that stops the windows going too far is missing!!! so what i have to do is, sit in the car (door closed), send the window all the way up, then quickly tap the down button to send the window down a tad. was a pain at first, but got usd to it now Link to comment Share on other sites More sharing options...
Guest MR G Posted February 4, 2008 Share Posted February 4, 2008 Hi All, Thank you for all your help With Haynes in hand I decided to tackle the window yesterday. Removed the doorcard and had the same problem as above. No screw. So I removed the interior plastic cover and had a good look. It seems that the adjustment bolt is not where haynes points out, but much further back and lower. You should be able to see that the bolt can move up and down if you unscrew it. Lower the window entirely, undo the bolt slightly and push it down to adjust down, and up to go up. I will try and take some photo's when the doorcard is next off for those who have this type of motor like me... The window now shuts 100% on the drivers door, though the passengers is just not quite right. I think it is due to a stiff seal on the hood.... Mike Link to comment Share on other sites More sharing options...
