Mk5 Electric Roof Issue
Guest RSSeries1
Guest RSSeries1
Hi,
I am a newbie so be patient with me, I have spent hours trailing the Roof Problems section trying to find an answer but it keep illuding me.
My wife has a MK5 Cabriolet, when she brought it the roof fitted fine, over the years however a large gap has appeard in the front and the locking pins dont seem to pull the roof closed propoerly which means you have a gap it leaks and it makes a god awful noise on the motorway.
I have tried previously to release the bolts and adjust but the pins dont seem to fit like they are too small or we are missing a seal or something by the front as the windows line up pretty much as they should and the roof is taught.
I will get some piccys up tommorow but does anyone have any ideas?
Cheers
Guest RSSeries1
You can try to adjust the roof locking handle hooks so they extended further, it has a little screw by the side, then you twist the hooks round to extend it.
That been done we have even moved the pins and tried everything to make it fit but it dont!
