More Zetec Questions
badger
hi gang
well here goes i have a mk4 1.6 carb and want to put 2 ltr mondeo lump(which i have in garage) in i know i need to replace sump,flywheel,water pump etc etc. what i need to know is fuel system? do i go for twin 40's or injection (what would i need to do this),
exhaust solutions (what best for this)and i'll need to upgrade brakes as well (it's no good going like s**t if you can't stop the bugger)
i'm pretty good with a spaner and have rebuilt a zetec after head gasket went,replaced clucth's and done straight forward engine swaps so i'm ready to take on anything just need as much advise to steer me in the right direction and pick up the views of those that have done this before...any help will be most welcome....
Guest markeyboy
there are loads of different brakes that ya can fit to the mk4, with the rsturbo ones probably being the easiest (maby stright swap)
no2lurch has just finished putting a zetec in his mk4, try to get in touch with him about the other bits you need, hes also fitting rst brakes to his
as for the other bit suchas fueling and the ignition im afraid i cant help
best of luck tho matey
  • 2 weeks later...
Guest no2lurch
markeyboy is right... i have just put a zetec engine in, and i am goign to put rst brakes on too.
have a look in the 'show us yours' sction as i have a thread i there with info and pics. regarding the brakes, you will need 15 inch rims, rst disks, capiliers and pads. they just bolt on.
cheers for that fella i'll have a look
still not sure what direction i'm going in but hey what the hell, nothing ventured, nothing gained
i do like the look of the mk4 engine bay with the zetec in ........ i love looking back at what mine was like
very nice indeed i don't think mine will ever look like that i'm not a show type of man just want more power.do you know anyone who has
a zetec conversion with twin 40's or am i better to go down efi route (it seems thats what they all have)
and remember i have a 1.6 cvh carb at the mo.
ok theres one guy on here who is about to go the twin carb route but that will be useing a ecu to power the coil pack
what everway you go you will need a ecu ie efi mk4 one or aftermarket .......
the hardest part of doing a efi loom change it geting hold of the loom .....
i get what your saying i was going to look for a scraped escort with efi and take everything i need, i know a few lads that work in the scrap yards they said they'll bell me if one comes in.
well its the best and easyest way ...... dont go the mk5/6 loom way as its to much work and restrics the engine
the mk4 1600 efi loom on the 1800 zetec 1 works well and 2 gives better power and touqe
also better for the mot as you have a higher emisions level then if you was using the mk5/6 loom and engine with the cat ......
let me know what where and when lol when your ready plus if you look in the engine tuning section there is some poasts about the zetecs and whats needed and so on .....
ok fella thanks for the help i'll contact ya when i'm up and running on the project i'll also post pics as i go so everyone can see what i'm doing and refer to it if they need.
