Guest Charley Posted November 28, 2007 Share Posted November 28, 2007 Hey not sure if this has been posted before but my alarm keeps going off when i open the door, it has only been doing this since the bad weather and the car getting wet inside from a leak at the window. I was gonna take the fuse out but realised that fuse also controls the locking of the car. Any suggestions?? It's becoming quite annoying now :throw: Oh and i know once i get the window sorted and not leaking it will be ok but i'm having problem after problem with that and now i'm runnin out of time and money to fix it Link to comment Share on other sites More sharing options...
Guest Eggsy Posted November 28, 2007 Share Posted November 28, 2007 have a GOOD look inside the boot near the rear lights (cant remember wich 1) behind the trim is your alarm horn - see if you can unplug it from there Link to comment Share on other sites More sharing options...
Guest Charley Posted November 28, 2007 Share Posted November 28, 2007 Thanks eric i will do that a bit later Link to comment Share on other sites More sharing options...
Guest sjc Posted November 28, 2007 Share Posted November 28, 2007 wot sort off alarm is it ??? how do you stop it once you have opened the door ??? is it remote on key fob? Link to comment Share on other sites More sharing options...
Guest Charley Posted November 28, 2007 Share Posted November 28, 2007 It's standard Ford alarm. I just unlock the door with the key. No just central locking not remote central locking Link to comment Share on other sites More sharing options...
Guest sjc Posted November 28, 2007 Share Posted November 28, 2007 put a new battery in the key fob maybe? Link to comment Share on other sites More sharing options...
Guest Charley Posted November 28, 2007 Share Posted November 28, 2007 I don't have a battery in the key fob, i just have a key Link to comment Share on other sites More sharing options...
Guest sjc Posted November 28, 2007 Share Posted November 28, 2007 is it a key with a red bit on? Link to comment Share on other sites More sharing options...
Guest Charley Posted November 28, 2007 Share Posted November 28, 2007 No not got a red bit Link to comment Share on other sites More sharing options...
Guest sjc Posted November 28, 2007 Share Posted November 28, 2007 well ignore me then charley sorry...thought it may have been like the standard alarm i had on a 95 model...it comes with a master "programmed" key that has a red bit on it....there is a sequence in the handbook on how to program a new key....but this may be a different alarm then. sorry X Link to comment Share on other sites More sharing options...
Admin Ollie Posted November 28, 2007 Admin Share Posted November 28, 2007 It's standard Ford alarm. I just unlock the door with the key. No just central locking not remote central locking hi charley i had one of these on my sierra if you can get to the actuater on the inside of the door lock disconect it from there for now till you get time to have a proper look Link to comment Share on other sites More sharing options...
Guest Charley Posted November 29, 2007 Share Posted November 29, 2007 I found where i think the alarm is (on the side with the roof hydraulic thing) but not sure what i'm unplugging, anyone able to put a pic up to show me? Please????? Link to comment Share on other sites More sharing options...
