Guest matt-the-dj Posted October 6, 2007 Share Posted October 6, 2007 hi chaps,i want to get rid of some small scratches and key gauges and imperfections in the paintwork, someone suggested paste and water with a light buffing wheel,suggestions as to which make to go for and how to do it. thanks Link to comment Share on other sites More sharing options...
Guest nickscunny Posted October 6, 2007 Share Posted October 6, 2007 t-cut Link to comment Share on other sites More sharing options...
Guest Eggsy Posted October 6, 2007 Share Posted October 6, 2007 well m8y its depends if its actually gone through to primer if it has then you talking paint - if it hasn't then a 1500 wet & dry dpending on paint, be carefull not to go through or your talking paint!! (pmsl) then buff it with finishing polish & water, you'll find that 3m is the best gear & if its paint contaminant 3m do a putty that really is the dogs danglies!!!! Link to comment Share on other sites More sharing options...
Guest matt-the-dj Posted October 6, 2007 Share Posted October 6, 2007 so for the deep keyed scratches , build up with paint , then wet and dry then paste? Link to comment Share on other sites More sharing options...
Admin Ollie Posted October 6, 2007 Admin Share Posted October 6, 2007 hi matt get yourself some G3 and a machine polisher with a white mop head ( be carefull of edges and corners m8 ) or take it to your local valeting company and they will do it for you for around £60 outside only Link to comment Share on other sites More sharing options...
Guest Eggsy Posted October 6, 2007 Share Posted October 6, 2007 so for the deep keyed scratches , build up with paint , then wet and dry then paste? is it met? right - if you paint over a scratch usually in the case of a deep scratch, you would rubb it down & feather it out, if you where painting the door, it all depend on what u wabt to do? if its a solid colour it much easier to lose by building it up slowy until it pertrudes the normal paint, ensuring you leave more than enough time for it to dry (7 days fully) then rub it doen with a fine paper on a block until flush, then go over it with a good polishing compound & a mop. paste? are you refaring to compound?? putty is for paint contamination i.e heavy rd grime/fallout/overspray ect Link to comment Share on other sites More sharing options...
Guest matt-the-dj Posted October 6, 2007 Share Posted October 6, 2007 thanks for all the help, ill have a go,if i bodge it i will have a strong case for a respray..............lol whooopeee she cant say no, all i need to do now is find the right colour paint, hopeully i can match it using the code on the vin Link to comment Share on other sites More sharing options...
Guest Eggsy Posted October 7, 2007 Share Posted October 7, 2007 thanks for all the help, ill have a go,if i bodge it i will have a strong case for a respray..............lol whooopeee she cant say no, all i need to do now is find the right colour paint, hopeully i can match it using the code on the vin & very good luck on that m8 i had murder with mine but its quite a l8 one!! pmsl Link to comment Share on other sites More sharing options...
Guest matt-the-dj Posted October 7, 2007 Share Posted October 7, 2007 1 problem 1 code for 2paints = confused Link to comment Share on other sites More sharing options...
