Ford Locking Wheel Nuts...
Guest DorsetDriver
Guest DorsetDriver
Question.... The previous owner didn't give me the key for the nuts and says he can't find it and I have a need for getting one of the wheels off fairly soon and wondered, can Ford supply me with a replacement OR is there a trick to whipping 'em off.
When I was Foreman at a big scrappie and dismantlers in Bournemouth, we used to air-guns after cutting edges on the nut but alas I have only hand tools and brawn to tackle this now.
Cheers
DD
Guest andy0406
Cheers
DD
I work at a scrap yard and I have found if we do not have a locking key we hammer a larger socket on and it normally does the trick
or use the correct tool for the job...... snap on wheel nut removers they come in a set of 4, left hand thread so as you do it up it comes off.
Simple.
Marcus.
Guest andy0406
Simple.
Marcus.
cheers for the heads up, sounds good, do you know how much they cost????
ask the local scallies they should be able to whip'em off in minutes! :rolleyes: lol
think u can get a socket that that will fit & grip over any nut, made by jml i think?
if not let me know how you got yours off - as my new blue came with no locker nut either
Edited by Eggsy
Guest suffolk04
did ford do a locking wheel stud/bolt set for the mk4's? i'm looking for a set, but theres loads of different sizes of bolts.
what make does everyone else use?
