Guest chrisw Posted August 12, 2007 Share Posted August 12, 2007 when the cars running theres a smell of fuel from under the car around the tank its not leaking just a smell its not from the exhaust also the fuel pumps buzzing louder than normal you can hear it over the engine from 6 foot away from the car any ideas? Link to comment Share on other sites More sharing options...
Guest hightower Posted August 24, 2007 Share Posted August 24, 2007 Hi chrisw My cabs fuel pump is making the same noise I`ve just ordered one from my nearest bullseye motor shop cost me £97 Funny thing is halfrauds wanted more for an inferior fuel pump to the one I`m getting so stay clear. Here`s the amazing thing after speaking to a close friend who works at my local ford dealer after looking she told me it could be the original :wow: she found a code on it somewhere???? if this is true it`s nearly 20 Link to comment Share on other sites More sharing options...
chaz Posted August 25, 2007 Share Posted August 25, 2007 I have mentioned this before on here as this question been asked a few times before. When I bought my cab my fuel pump buzzed real loud and also you could hear with engine running from 6 ft away but it kept on working for about a year with the odd misfire and the odd non starting when hot. When I came to replace it the ford dealer wanted 120 Malta pounds, and through my mate who is a mechanic got the same spec pump from Germany for 45 Malta pounds including postage. When we replaced it he reckoned it was also the original pump and now you can just hear a very low buzz when its in the garage you cannot even hear it when its outside, at the same time I also replaced the fuel filter, this should be replaced at least every other year. Link to comment Share on other sites More sharing options...
Vincygav Posted September 7, 2007 Share Posted September 7, 2007 Check the return hose to the tank, I had this problem. After years, it seems to come off slightly from pressure. I took both the supply & return off, and fully push them right in, never had a problem with the fuel smell after that. Link to comment Share on other sites More sharing options...
