Electric Roof
Guest Tim64cars
Guest Tim64cars
Hi All
i have just bought a mk6 with an electric roof the bloke says the roof goes half way up and stops the goes half way down
is this one of those cogs that needs replacing?
or could it be something else
Guest markeyboy
it could be just low fluid m8,
i dont think it would move very far at all if the cog was fooked
Guest Tim64cars
cool i can check all this when i've picked it up and i will look as though i know what i'm doing lol
Guest Tim64cars
The level is just below min so i guess it is that. however it has failed it's mot on the below so getting it on the road is the first thing to do
He failed!!!!!!
on the hand brake
front suspension joint
rear wheel bearing.
£210 including the mot..
advisorys, erm 8
brake pipes are corroded simple job so i have been told X3
bleeding tyre i knew i shud have changed them anyway but i have left them with the car. my st ones
velocity joint gaitor deteriorated.
anti roll bar link cover split.
and an oil leak needs a top up.
my friend is going to do the advisory's
the garage is doing the failed bit. so Sarah is driving it home on wednesday from norfolk..
at the first hurdle i was ready to break it up and keep the banana my mate convinced me otherwise,
so the banana is up for sale but he won't have wheels until wednesday and won't be ready until next weekend.
Guest markeyboy
its good to hear that you didnt decide to break it, mine has got its niggles too, like rear wheel bearing is noisey, handbrake is total shite etc
when youv done it you should have loads of trouble free miles
Guest Tim64cars
this is how he looks today...
Pip I bet you convinced Tim to get a MK6 lol, cab looks good Tim
when you get it post some pics.
chaz it had to b done lol
Guest Eggsy
it must be them brake pipe gremlins apparently they don't like the nsf brake lines, but it just depends what position your car is parked in - they're a bit like twockers - the little bastards!!!!!!
