Guest Dazzaas Posted July 11, 2007 Share Posted July 11, 2007 just bought of reid a bigger throttle body ti fit to my 105 zetec but the cable mount points upwards do you use 105 bracket or the one thats on there if so will it rub on bonnet ? Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted July 11, 2007 Share Posted July 11, 2007 first what manifold dose you zetec have big metal one with efi on top or a plastic black one ? second have you a pic of the throttle body or know what its off ie escort or mondeo ? Link to comment Share on other sites More sharing options...
Guest Dazzaas Posted July 11, 2007 Share Posted July 11, 2007 i have big metal efi Link to comment Share on other sites More sharing options...
Guest Dazzaas Posted July 11, 2007 Share Posted July 11, 2007 this is throttle body poss mondeo Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted July 11, 2007 Share Posted July 11, 2007 yep mondeo looking at bracket ,,, ok so you will need to fit yours ..... it should fit Link to comment Share on other sites More sharing options...
Guest Dazzaas Posted July 11, 2007 Share Posted July 11, 2007 nice one thats a job for the weekend then Link to comment Share on other sites More sharing options...
Guest diane Posted July 12, 2007 Share Posted July 12, 2007 like the way you say SHOULD Tony lmao Link to comment Share on other sites More sharing options...
Guest benny Posted July 18, 2007 Share Posted July 18, 2007 let me know what happens? i need to do something to mine to speed it up, i just think its slow! need more speed, and dont know where alse to go unless i turbo and i dont really wanna? Link to comment Share on other sites More sharing options...
Guest Dazzaas Posted July 18, 2007 Share Posted July 18, 2007 well its fitted wot a pain tryed using throttle linkage off mine didnt fit throottle position sensor wrong way round so caught on icv. cable holder wont fit had to manufacture one from scratch. mondeo linkage had to be trimmed cos rubbed on injectors and fuel feed pipe was it worth it well........ sounds throatier but no gain in performance well not that you can tell anyway maybe coupled with exhaust and ecu but at the moment no difference so gutted Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted July 18, 2007 Share Posted July 18, 2007 have you made sure its opening all the way when the throttle pedel is depresed? Link to comment Share on other sites More sharing options...
Guest Dazzaas Posted July 22, 2007 Share Posted July 22, 2007 update have now fitted new maf sensor aswell now there is adifference not major but midrange power has become sharper and lasts longer so happier now Link to comment Share on other sites More sharing options...
Guest enzo Posted July 22, 2007 Share Posted July 22, 2007 hi i put a 2 litre one on mine was just a case of swaping throttle bodie but had to swap the bracket that holds the cable with my old one took 5 mins thanx to instructions from tony ps mine was 115 psi zetec Link to comment Share on other sites More sharing options...
Guest enzo Posted July 22, 2007 Share Posted July 22, 2007 Sorry im thick maf sensor is that the same as air flow meter or comp-letely diferent thing Link to comment Share on other sites More sharing options...
Guest Dazzaas Posted August 4, 2007 Share Posted August 4, 2007 Sorry im thick maf sensor is that the same as air flow meter or comp-letely diferent thing mass air flow sensor so same as Link to comment Share on other sites More sharing options...
