Guest robbo1 Posted November 16, 2006 Share Posted November 16, 2006 hi everyone , firstly i would like to say this website is tops for info etc, whitch i hope someone can help me with a problem im having, ive got a kenwwod headunit to fit in my cabby, i know the the blue wire is for amp or ariel, but i want to use it for both ,cold i take said wire to the amp as usual and also join same wire to electric ariel , does the car have a wire as standard at plug end behind headunit, and if it does what colour is it, so i could join ther so when a power up headunit amp and ariel get power, any help would be great, thanks in advance, cheers robbo Link to comment Share on other sites More sharing options...
Guest robbo1 Posted November 16, 2006 Share Posted November 16, 2006 yes that will work but your pobably best doing aerial off the ignition then amp off stereo because it'll split the power and depending on current might not get enough power to one of them hope this helps taz thanx for advice mate, will try that way , cheers robbo Link to comment Share on other sites More sharing options...
