Guest Sirrel Squirrel Posted August 20, 2006 Share Posted August 20, 2006 Planning on getting some 4" infinity speakers for the front and rear of my mk4 cab, just wondering what kind of speaker connection is already there, is it the dodgy ford connecters or just standard red and black cable tied around a bit of metal on the speakers? Can you get adapters if it is the Ford type? Link to comment Share on other sites More sharing options...
Guest markeyboy Posted August 21, 2006 Share Posted August 21, 2006 knowing fords it is probably the dodgy ford connections, when you stick ur new speakers in cut the old connectors off and crimp on the correct spades to fit, Link to comment Share on other sites More sharing options...
Guest mk4chris Posted February 8, 2007 Share Posted February 8, 2007 knowing fords it is probably the dodgy ford connections, when you stick ur new speakers in cut the old connectors off and crimp on the correct spades to fit, Don't do this as it will kill most modern stereos. the ford shared earth is a bastard for anything that isn't a ford. run new wires to each speaker is the only proper way to do it. Link to comment Share on other sites More sharing options...
