Guest POULTRY Posted April 25, 2006 Share Posted April 25, 2006 before i start just like to add the fact this is about my 6th ICE install and so far have never had any problems, and not just the basic amp and speaker. This is my last hope of help , its just a basic amp and set of 6x9`s , problem is with a crackling from the speakers, now i`ve added better grounding from the battery to car and amp to car , all cables are wired away from each other ,bought new RCA cable did`nt work, i plug my mp3 player into the amp via a diffrent cable and got no crackiling whatsoever , so it can`t be the speaker/amp , obviously the RCA is cable is close the the antenna cable in the back of the headunti, but this has never been an issue before only other thing i can think of is that the electric aerial is causing interferance, anybody please HELP peace poultry Link to comment Share on other sites More sharing options...
Guest bloopeta Posted April 25, 2006 Share Posted April 25, 2006 are you sure the RCA lead isnt running near any power wires?? you can buy a supressor from halfords etc which may eliminate the noise. Link to comment Share on other sites More sharing options...
Guest POULTRY Posted April 26, 2006 Share Posted April 26, 2006 well i un wired the rca cables last night so they came straight out of the headunit outside of the car then back into the boot , and still i had the noise, i`m gunna take the headunit back cose as far as i can see it has to be the headunit , as system works fine with mp3 player, or could i be drastically wrong ????? Link to comment Share on other sites More sharing options...
Guest markeyboy Posted May 2, 2006 Share Posted May 2, 2006 the exact same thing happend with one of the head units that i had in my old fiesta, wgen the engine reved th speakers bussed with the engine, wien i got a new head unit this problem had magically cured Link to comment Share on other sites More sharing options...
