Guest kriscab Posted April 5, 2006 Share Posted April 5, 2006 i have just bought a escort cab mk 5 and its got a cat 1 laserline alarm and imo, not got any instructions with it,its like hens teeth 2 try and get any info from any dealership,my prob is that evry night the alarm decides 2 go into disco mode,never dose it through the day always at night,i have kicked the car banged the bonnet and it dosnt go off,can any one help me with this or has someone had the same prob,it drivin me nut`s.... :bowdown: :bowdown: :bowdown: Link to comment Share on other sites More sharing options...
Guest David Posted April 5, 2006 Share Posted April 5, 2006 Hi mate, Hope this help's. Depending on how old it is depends on which buttons you press, turn off alarm and watch the L.E.D if it still flashes count the flashes. If it doesn't flash you need to press the two button's on the fob at the same time, the two opposite each other. If L.E.D off it thinks it's ok. 1 to 10 flashes there's a problem Either post here or pm me and i'll tell what it is as i'd be typing it out all night. Hope this helps you. David Link to comment Share on other sites More sharing options...
Guest kriscab Posted April 6, 2006 Share Posted April 6, 2006 i have just bought a escort cab mk 5 and its got a cat 1 laserline alarm and imo, not got any instructions with it,its like hens teeth 2 try and get any info from any dealership,my prob is that evry night the alarm decides 2 go into disco mode,never dose it through the day always at night,i have kicked the car banged the bonnet and it dosnt go off,can any one help me with this or has someone had the same prob,it drivin me nut`s.... :bowdown: :bowdown: :bowdown: thanks m8,i will give it a go but im thinkin about takin it out and gettin just a imobiliser fitted, disconected the internal sensors to c if that would help but still doing the same,got 2 the stage now that it making the battery go flat,i have taken the plug out of the siren but lights still flash, :bowdown: :bowdown: Link to comment Share on other sites More sharing options...
Guest David Posted April 6, 2006 Share Posted April 6, 2006 thanks m8,i will give it a go but im thinkin about takin it out and gettin just a imobiliser fitted, disconected the internal sensors to c if that would help but still doing the same,got 2 the stage now that it making the battery go flat,i have taken the plug out of the siren but lights still flash, :bowdown: :bowdown: Don't rush and rip it out, check the l.e.d's because for instance 9 flashes just means the remote control is nearly flat and needs changing. If this was the case about £1.00 for battery or £100 for new imoboliser. Good luck David Link to comment Share on other sites More sharing options...
Guest kriscab Posted April 7, 2006 Share Posted April 7, 2006 Don't rush and rip it out, check the l.e.d's because for instance 9 flashes just means the remote control is nearly flat and needs changing. If this was the case about £1.00 for battery or £100 for new imoboliser. Good luck David hi m8,looked at it this morning about 3am and the led was flashing once,dose that mean anything 2 u.. chris Link to comment Share on other sites More sharing options...
Guest kriscab Posted April 8, 2006 Share Posted April 8, 2006 Laserline instructions check this website out hope this helps taz :bowdown: TOP MAN :bowdown: ,thanks for that m8,i will give it a go. Link to comment Share on other sites More sharing options...
Guest David Posted April 10, 2006 Share Posted April 10, 2006 hi m8,looked at it this morning about 3am and the led was flashing once,dose that mean anything 2 u.. one flash means voltage drop sensor, but check out that site mentioned in the other post. any problems come back to me. David Link to comment Share on other sites More sharing options...
Guest kriscab Posted April 14, 2006 Share Posted April 14, 2006 thanks to all that gave me help,i have now cracked it,alarm is working fine now,many thanks to one and all........ chris. :party09: Link to comment Share on other sites More sharing options...
Guest mr grady Posted March 10, 2007 Share Posted March 10, 2007 glad to hear it and thats what we are all here for can i ask what anyones opinion of laserline alarms are? i cant get the clifford 650 i bought fitted, and ive found a local guy who will fit a Laserline 290i2 for 185 notes. btw, glad you got yours sorted kriscab. Link to comment Share on other sites More sharing options...
Guest joeauk Posted March 16, 2007 Share Posted March 16, 2007 dam i had some instructions but i chuked them awaly mate coz i took mine out of my car coz im now getting a clifford Link to comment Share on other sites More sharing options...
