Guest bloopeta Posted April 4, 2006 Share Posted April 4, 2006 call me stupid if you like, but what does it take to convert a manual roof to electric?? is it just a case of motor and rams etc? of do you have to change the frame?? also my mates has some sort of clips that holds his roof down, mine doesnt, so does this mean mine once was electric?? my heads battered, I need a rest LOL Link to comment Share on other sites More sharing options...
Dan4114 Posted April 4, 2006 Share Posted April 4, 2006 Found this website a little while ago bloopeta ( CLICK HERE then if you click on electrics your see a link for power roof ) Dont know if it will help you out any as its for a mk3. Link to comment Share on other sites More sharing options...
Guest bloopeta Posted April 4, 2006 Share Posted April 4, 2006 yep just a case of rams etc but you do have to alter the frame and put in some bolts that the rams attach to not sure about yours once being electric but every roof i 've seen wether elec or manual has had roof handles at front that clip the roof down ??? sorry I think you have misunderstood what I mean bud, I have handles at the front that clip roof down, ofcourse i do, what i mean is he has things that clip his roof down at the bac, when the roof is down Link to comment Share on other sites More sharing options...
Guest Keith Posted April 4, 2006 Share Posted April 4, 2006 The clips at the back are only on the manual roof to keep it from lifting when the roof is down. If you fit a power kit you need to cut these off with a grinder else the roof wont lift up, obviously, and end up knackering either pump or ramps at worst. Also you need to change the ram mounting bolts as they are different on the power rams but you may have problems getting hold of the top pins unless they come with the kit you get. Apart from that its easy to do you just need to wire it up, fit the pump out of the way and enjoy. Ive just put electrics on mine and it was easy as, much better now having power. Link to comment Share on other sites More sharing options...
Guest enzo Posted April 4, 2006 Share Posted April 4, 2006 ok i m a noob and i converted my old mk4 roof to electric about 9 years ago and u could grind the clips of but what i did was just used plastic ties to hold them permanatly open and this worked fine m8if u aint got them then it probably means it was power roof 1 day mayb if i can b of any help m8 just ask but bare in mind i am anoob Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted April 4, 2006 Share Posted April 4, 2006 If you remove the plastic cowls that the manual levers are in, you can undo the bolt that holds each one, rather than grinding them, it only takes about 5 mins longer to do. the wiring loom is fairly straightforward and if you cant get the correct switch, one for the passenger side electric window from a mk4 will do. Link to comment Share on other sites More sharing options...
Guest bloopeta Posted April 4, 2006 Share Posted April 4, 2006 cheers peeps, mine must have been elec at some point coz Ive got no clips holding roof down when down, Ive already got a Mk4 passenger window swith down near my handbrake, I stuck it in there to fill in the hole when I bought the car, thanks for the advice, just need to find a pump etc now. Link to comment Share on other sites More sharing options...
Guest Keith Posted April 5, 2006 Share Posted April 5, 2006 cheers peeps, mine must have been elec at some point coz Ive got no clips holding roof down when down, Ive already got a Mk4 passenger window swith down near my handbrake, I stuck it in there to fill in the hole when I bought the car, thanks for the advice, just need to find a pump etc now. Give Tony a shout as im sure he's got one for sale Link to comment Share on other sites More sharing options...
escortcabrioletclub Posted April 5, 2006 Share Posted April 5, 2006 i have got one for sale lol Link to comment Share on other sites More sharing options...
Guest bloopeta Posted April 7, 2006 Share Posted April 7, 2006 is it for a mk5 mate?? Link to comment Share on other sites More sharing options...
