Guest ESCYNEIL Posted March 24, 2006 Share Posted March 24, 2006 does the escort cosworth centre console fit a standard mk5 dashboard? also the strip on the passenger side of the cossie dash is it possible to fit one to a standard dash?would prefer to fit a full dash complete with bannana pods but they are rare and expensive any advice welcome. Link to comment Share on other sites More sharing options...
iansoutham Posted March 24, 2006 Share Posted March 24, 2006 does the escort cosworth centre console fit a standard mk5 dashboard? also the strip on the passenger side of the cossie dash is it possible to fit one to a standard dash?would prefer to fit a full dash complete with bannana pods but they are rare and expensive any advice welcome. The pod section that runs along the passenger side of the dash is compatible with a standard dash assembly. However, the centre console section will not be compatible as it is designed to run with a transmission tunnel from a Sierra (i.e. 4wd / rwd). Therefore, a gap will be present between it and the bottom of the dash. All the extension and so on will be wrong as well. Link to comment Share on other sites More sharing options...
Guest Dan102030 Posted March 25, 2006 Share Posted March 25, 2006 You could probably fit it with a bit of cutting and changing but like was said u will have 2 find something 2 fill the hole between it and the dash, i think a nice home made panel with some gauages in would look nice or mayb fit a CD changer in there Link to comment Share on other sites More sharing options...
