Amp mk5
Guest kevscabriolet
Guest kevscabriolet
Hi all.
Just wonderin if anyone has come across a stupid little thing whilst installing a amplifier into a cab.
Where the hell does the positive wire go?? ive fitted quite a few amps but not in a cab unfortunately now i want some serious sounds in the cab, i've looked for a hole under the bonnet and a grommet all usual places anyone got any ideas would be much appreciated. By the way its a M reg pre facelift mk5 1.8 si if this helps lol. Thanks everone
Kev
Just drill a hole through, but make sure there is nothing the other side and you put a gromet round to seal it and stop the wire from rubbing, depends on the size of cable you are using
  • 4 months later...
