Guest jimmyush Posted May 14, 2016 Share Posted May 14, 2016 (edited) Hi all really need some help with the rotor arm... currently my car has the 6500 rev limited arm.. these are starting to get rare. i got 2 from car parts 4 less but im wondering if i can change to the other type. any advice would be great... thanks Edited May 14, 2016 by jimmyush Quote Link to comment Share on other sites More sharing options...
iansoutham Posted May 18, 2016 Share Posted May 18, 2016 All you need is the cap and rotor arm from a non-injection version with the Bosch cap. Had it on all my old xr3i models. The power drops off around 5000rpm if you leave it in. Doesn't work well if you have a cam that is working until over 6000 rpm having a restrictor like that. Quote Link to comment Share on other sites More sharing options...
Guest jimmyush Posted May 21, 2016 Share Posted May 21, 2016 All you need is the cap and rotor arm from a non-injection version with the Bosch cap. Had it on all my old xr3i models. The power drops off around 5000rpm if you leave it in. Doesn't work well if you have a cam that is working until over 6000 rpm having a restrictor like that. OK so I can fit the other type of arm?? My system is bosch. I have loads of new caps which will work with the arm. Just making sure I'm safe using it. Quote Link to comment Share on other sites More sharing options...
