Guest Aaron James Sadler Posted April 13, 2015 Share Posted April 13, 2015 I have replaced the radiator fan switch, the thermostat seems to be working fine but the fan doesn't kick in until the needle is up in the red, is there a way to adjust this? It's the efi engine Quote Link to comment Share on other sites More sharing options...
Guest Joe35 Posted April 27, 2015 Share Posted April 27, 2015 My cabby is a MFI but my fan starts as soon as I turn the key, ive asked on here about it and people say someone might have rewired it so it stays on, they also have said there is a black block on top of the drivers side wing, I disconnected it and the fan didn't come on, I left it until the temp got so high I didn't like it so turn the engine off reconnected the block and I'm leaving it,I did changed the 88 thermostat which didn't change anything,not sure if the EFI connection is the same but worth a look Quote Link to comment Share on other sites More sharing options...
Stephen Bearded Minky Hill Posted May 8, 2015 Share Posted May 8, 2015 Mine gets quite high on the gauge before the fan kicks in too, I also have a new stat and thermo switch. It is also efi turbo. Quote Link to comment Share on other sites More sharing options...
