Help!!!!!!!!!!!!!
Guest Dell boy
Guest Dell boy
My D reg mark 4 ticks over fine for hours but once I drive it for a couple minutes it stalls and fails to restart for about 5mins.it has immobiliser which is working fine..I have recently put a fuse back into the thatcham alarm,could this be the problem
Guest El87cabi
If the alarm and Immobiliser are separate then i'd say no, wouldn't hurt to remove the fuse you replaced to see if the fault abates, without having that issue with my previous mfi cab i'd say more info is required, either way sounds like a fun game of find the fault :mellow:
