welshlad Posted September 4, 2014 Share Posted September 4, 2014 Had a starting problem with my car for a long time, new starter motor and battery fitted etc, and fitted new battery terminals, earth cable and cable lugs the other day that i bought from Demon Tweeks based in wrexham near me, the starting problem seems to be solved (3 x days of no problems ) but earlier today it wouldn't start as usual but not the usual low battery type of not starting but a intermittant no starter motor engaging type of not starting! like my wife has said and its happened more to her than me she thinks its the alarm as the LED flashes red so obv i/we lock and unlock the car with the fob and after a few times its ok and lets us start the car Anyone else had the same problem? Ive bought a new Toad Ai606 main brain module of ebay but dnt want to take the clocks out and open the steel security casing to replace it if i dnt have too as it may or may not be the alarm ? only other possibility is the ignition switch? perhaps thats faulty? Quote Link to comment Share on other sites More sharing options...
Vincygav Posted September 10, 2014 Share Posted September 10, 2014 Does it seem to happen when the car has gone after a run i.e. hot start problem; or lefts a few days without starting. Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted September 11, 2014 Share Posted September 11, 2014 Most alarms have imobilsation in the following three ways. Fuel pump, Starter motor and ignition system. It can have only one of the following or all three. Toad Ai606 which is the same as I have has dual imobilisation. Fuel pump and ignition system as reccommended. But who ever fitted it can disable any system. This is done on early models with external relays ( most likly the fault you have if the alarm is to blame) On later models the relays are built into alarm. You'll need to trace the wiring from the ignition barrel back to see if you can find the relay. The starting issue you discribe are most likly poor connections on the starter. They need to be really clean i.e. wire brushed and sanded. Copper grease is ideal for putting on before doing them up tight. Easy way to tell if its connections or the starter itself is next time it wont start bridge the gap on the terminals with a screwdriver. If it starts its poor connections Quote Link to comment Share on other sites More sharing options...
welshlad Posted September 11, 2014 Author Share Posted September 11, 2014 hi guys its intermitent and it hasnt done it all week i see what you mean lee about the two circuits etc i think the relays are built in (i have had it out of the casing to fit a dual stage micro sensor and had to melt the white connector on the board a little as the end would fit properly) its strange how it flashes constantly red when its not letting the starter get power, when otherwise its green, if it does it again i might just bite the bullet and swap it for the new main unit ive bought and i suppose the original one will be a good spare or i could ebay it etc Quote Link to comment Share on other sites More sharing options...
Guest escott1973i Posted September 11, 2014 Share Posted September 11, 2014 Hope you get it sorted mate! my cabbys just back on the road today starter just stopped working, Could of done with out it as am trying to get the tintop in the road an sort my cabby out over the winter. Quote Link to comment Share on other sites More sharing options...
welshlad Posted September 11, 2014 Author Share Posted September 11, 2014 im thinking of putting mine off the road to get it done for next year and my wife has agreed to me spending £1400 on a full leather retrim woo hoo i think its because ive sorted all the little problems with it that used to piss her off. so next month or so ill be driving around in a deisel Freelander Quote Link to comment Share on other sites More sharing options...
welshlad Posted September 12, 2014 Author Share Posted September 12, 2014 I spoke too soon... Alarm went off 11.30 last night and upon re arming the led was just constantly flashing green so it looks like later on the dash is coming out Quote Link to comment Share on other sites More sharing options...
Guest escott1973i Posted September 12, 2014 Share Posted September 12, 2014 your jinxed like me welshy must be summit about red cabbys lol Quote Link to comment Share on other sites More sharing options...
welshlad Posted January 21, 2015 Author Share Posted January 21, 2015 so you doing yours up over this winter? mines in a garage but getting it out sometime this week to see what needs doing and poss sand it down etc Quote Link to comment Share on other sites More sharing options...
