Guest we'll_always_be_blue Posted August 27, 2014 Share Posted August 27, 2014 my mk4 roof will only go down if i push it up about a foot to start it off, after that it carries on on its own. there's no problem with the closing, just when i try to open it, any ideas? Quote Link to comment Share on other sites More sharing options...
welshlad Posted August 28, 2014 Share Posted August 28, 2014 Try opening the roof with the key valve open on the pump and then open and close it manually 3-4 times then close the valve and try it with the switch again that should solve it Quote Link to comment Share on other sites More sharing options...
Guest we'll_always_be_blue Posted September 1, 2014 Share Posted September 1, 2014 Try opening the roof with the key valve open on the pump and then open and close it manually 3-4 times then close the valve and try it with the switch again that should solve it hi welshlad, i tried what you said and it starts to pull the roof but doesn't seem to have the strength to lift it. i'm starting to wonder if it needs oil or even new rams, i noticed there was a fair bit of oil around the rams but don't know if this is normal or not Quote Link to comment Share on other sites More sharing options...
gingergman Posted September 5, 2014 Share Posted September 5, 2014 Is the oil level in the pump ok? If its low it will struggle Quote Link to comment Share on other sites More sharing options...
Guest we'll_always_be_blue Posted September 12, 2014 Share Posted September 12, 2014 a quick update i put some hydraulic oil in and the roof now works a treat :-) i can't believe it was something so simple, Quote Link to comment Share on other sites More sharing options...
