Guest DRP091010 Posted August 24, 2014 Share Posted August 24, 2014 Hi, I need to run a live cable from the battery into the boot but I cant seem to find a way from the engine bay into the main car area. Can anyone help? Thanks Quote Link to comment Share on other sites More sharing options...
Skittles80 Posted August 24, 2014 Share Posted August 24, 2014 Across the bulk head along side existing wires near rubber trim down a oblong hole in drivers side bulk head then remove drivers side wheel arch liner near where the wire comes through there is a big rubber cromit going in to cab with big wires coming out make a small hole along side this wire will then go through this comes out at fuse box area in cab have feed a few wires through this way it's a hard job but neat and invisible I wired our electric roof this way and our fog lights and indicators good luck Quote Link to comment Share on other sites More sharing options...
Skittles80 Posted August 24, 2014 Share Posted August 24, 2014 This is based on a mk5 not sure what yours is Quote Link to comment Share on other sites More sharing options...
Guest DRP091010 Posted August 24, 2014 Share Posted August 24, 2014 Sorry MK5b/Mk6. Thanks I will have a look. Quote Link to comment Share on other sites More sharing options...
