Guest wolfetony Posted June 27, 2014 Share Posted June 27, 2014 Hi there does anyone know were i can buy roof oil for my cabby phoned the local ford dealer today and was quoted £33 for a ltr thanks but no thanks! Haynes manual says esso univis hvi26 but this obsolete as its now made with them and mobil and is now called mobil unvis hvi26 anyone know were i can buy this tried ebay cant seem to see any also tried halfords but theirs is recomended by certain manufacturers and ford is not one of them so didnt want to risk it any help would be greatly appreciated thanks. Quote Link to comment Share on other sites More sharing options...
Guest Michael Stevens Posted June 27, 2014 Share Posted June 27, 2014 http://www.escortcabrioletclub.co.uk/forums/index.php?/topic/19262-part-number-for-correct-hydraulic-fluid-for-power-roofhood/ Is it too much too pay? YesGo to your VW Dealer and ask for some Hydraulic fluid G004 000.500ml = £7.This is the fluid recommended by VW for use in its cabriolet pumps. Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted June 27, 2014 Share Posted June 27, 2014 Any PAS fluid will do Quote Link to comment Share on other sites More sharing options...
Guest wolfetony Posted July 11, 2014 Share Posted July 11, 2014 (edited) Thanks got some vw fluid as luck would have it my son is a vw mechanic. Cheers. Edited July 11, 2014 by wolfetony Quote Link to comment Share on other sites More sharing options...
Guest Tony Walter Posted July 11, 2014 Share Posted July 11, 2014 Hi guys I think this be my problem also, I now have to help the cab up and down as the system seems too tired, Where is the filling point placed ? Mine is 1995 xr3i 1.8 EFI motor. Many thanks for your kind thoughts. Best Wishes. Tony. Stockholm Sweden. ( lovely weather today), roof down, hope it doesn't rain, I can't swim...... Quote Link to comment Share on other sites More sharing options...
gingergman Posted July 12, 2014 Share Posted July 12, 2014 top it up in the pump in the boot mate Quote Link to comment Share on other sites More sharing options...
Guest tmatthews Posted September 24, 2014 Share Posted September 24, 2014 Hi Is there any sort of bleeding to do when you fill from empty The roof hasn't been down all year and the oil must have leaked out plastic bowl is empty. Any advice would be much appreciated. Trev... Quote Link to comment Share on other sites More sharing options...
welshlad Posted September 24, 2014 Share Posted September 24, 2014 unscrew valve key on the side of the pump and manually push it down and up 3-4 times then screw key valve shut that will sort it out Quote Link to comment Share on other sites More sharing options...
Guest Mark Leighton Posted October 25, 2014 Share Posted October 25, 2014 anyone got a picture of where you top the roof motor up. also how come the electric window only works on passanger side door same with electric mirror and central locking. thanks Quote Link to comment Share on other sites More sharing options...
