Guest James Rowe Posted June 13, 2014 Share Posted June 13, 2014 Hey, When the roof is down and you want to put it up you have to release the roof using the levers under the speakers. My drivers side lever has a plastic ball on the end to pull where as the passenger side doesn't. Does anyone know if it should have one and if yes can I buy one? Many thanks James Quote Link to comment Share on other sites More sharing options...
Skittles80 Posted June 14, 2014 Share Posted June 14, 2014 Is your roof manual or electric if manual these two bits are normal if it is a electric it means it was once a manual and these bits can be removed and yes there should be a small plastic cover on each lever I binned mine when I converted mine to a power roof best thing I ever done best of luck mark Quote Link to comment Share on other sites More sharing options...
Guest James Rowe Posted June 14, 2014 Share Posted June 14, 2014 My roof is a manual, was thinking of converting to electric but not sure. Quote Link to comment Share on other sites More sharing options...
Guest James Rowe Posted June 14, 2014 Share Posted June 14, 2014 I only have a plastic cover on the drivers side Quote Link to comment Share on other sites More sharing options...
