Guest Justin Richardson Posted April 8, 2014 Share Posted April 8, 2014 Hi all Do any of you know where or which ignition loom I need for a MK5 cab? I've got a new barrel but.... a few years ago when this car belonged to my mum it was broken into & due to some 'interesting' re-wiring to fix another fault (which it didn't) they couldn't get it started & just smashed the shit out out of the steering column. The problem I have is that the car electrician who fixed the ignition placed it in a different location with a crap little key and the original connections had been removed so I don't even know what the loom looks like!! I basically want to put the ignition back in the steering column with a proper car ignition. Any help would be much appreciated. cheers Quote Link to comment Share on other sites More sharing options...
Vincygav Posted April 10, 2014 Share Posted April 10, 2014 Erm its called an ignition switch loom, still available from Fords IIRC. Quote Link to comment Share on other sites More sharing options...
