Guest Couscous720 Posted April 3, 2014 Share Posted April 3, 2014 Hi i got my car a few moths back and i thaught the starter holding coil had gone but i was bumping it to get around and i have found that now i have a short that is draining the battery i only used it like twice cince the starter went for short journeys. The indercaters dont turn off and the drivers side rear light cluster turns all the lighs on when i turn on the lights (but its been like that a few weeks) can anyone help? The engine is running with a megajolt ECU and R1 carbs if that helps. Quote Link to comment Share on other sites More sharing options...
Guest Couscous720 Posted April 4, 2014 Share Posted April 4, 2014 Also could anyone tell me if i need a zetec starter or and XR3i one as it is still running the XR gear box? Quote Link to comment Share on other sites More sharing options...
Vincygav Posted April 4, 2014 Share Posted April 4, 2014 Sounds like your indicator/headlight stalk unit is gone. I guess it would be the XR3i MTX75 starter motor as it bolts onto the gearbox flange. Quote Link to comment Share on other sites More sharing options...
Guest Couscous720 Posted April 5, 2014 Share Posted April 5, 2014 Cheers for your help is there a way i can check this before i buy a new one? Quote Link to comment Share on other sites More sharing options...
