Guest Deputydawg Posted March 19, 2014 Share Posted March 19, 2014 I have a 1989 1.6 CVH XR3I Cab, it has a K jetronic injection system. The problem I have is it idles very low and when cold sometimes cuts out. According to some posts it has been suggested that I clean the idle control valve (ICV) or some say the lambo... Can anyone tell me if the are the same or if not were can I locate the lambo so I may clean both. I have a haynes so any help would be grateful Quote Link to comment Share on other sites More sharing options...
gingergman Posted March 20, 2014 Share Posted March 20, 2014 Do you mean lambda sensor? If so the mk4 don't have one, not even the EFI. Quote Link to comment Share on other sites More sharing options...
Guest Deputydawg Posted March 21, 2014 Share Posted March 21, 2014 Yes I think so? it is a MK4 so I guess you have answered my question. I guess I should clean the idle control valve eh! Quote Link to comment Share on other sites More sharing options...
gingergman Posted March 21, 2014 Share Posted March 21, 2014 Is yours the MFI system? Quote Link to comment Share on other sites More sharing options...
Guest Deputydawg Posted March 22, 2014 Share Posted March 22, 2014 I am not sure, how can I tell? according to haynes it has the K jetronic fuel injection system. when you look at the engine it has a a solid piece of aluminium near the dashboard bulkhead....if that helps you? Quote Link to comment Share on other sites More sharing options...
