How To Change Ford Torch Key Bulb And Battery
Vincygav
Thought I would do a how to with pics on changing the bulb & battery on torch key.
Push the Ford logo on the key to release the battery/torch compartment.
Use the flat screwdriver or your nails to prize it apart in half
Get your battery and bulb ready, trying not to touch the battery leaving fingerprints
Give the contacts and bulb holder and body a clean
Once clean, install the bottom copper contact
Then install the spring, make sure its under the lug on the key
Install the upper copper contact which touches the base of the bulb
Install the new bulb
Place the new battery under the button holder then rest it on the spring
place the cover over and push it into place, fitting squarely
Test the light for operation, if it is on permanently, reopen and twist the spring the reinsert
Fit back into the main key body and test, JOB DONE!
