1.7 Zetec Into My 1.6 Efi
Guest slipstream
Guest martinkettering
Need complete engine loom,ecu,transponder,get cambelt changed by somebody who has previously done the 1.7vct as they are a pain to do,and can easily kill an engine if not set up correctly,use correct timing tool,and not the frp tool.
Will you be running powersteering?
You will be better running a tape ecu as this only needs 1 lambda sensor and also works with analogue dash,change gearbox as starter is at the front of the engine not the rear.
Guest slipstream
thank you i now have the complete car (puma) sat on my drive so i can use every think i need , will i need the fuel pump or will the cabby one do the same job
