Guest GINGExR2T Posted February 11, 2014 Share Posted February 11, 2014 (edited) . Hi all, Picking up a 90spec Cabby later today but it has a manual roof, I have another cabby which has a power one so gonna change it over at some point, do I have to change the whole thing (complete roof with frame etc) or can the power motor be fitted to the non-power frame. I need the roof on the doner car to work afterwards aswell. Cheers Ginger . Edited February 11, 2014 by GINGExR2T Quote Link to comment Share on other sites More sharing options...
badger Posted February 11, 2014 Share Posted February 11, 2014 you can just change the pump/rams and mounting pins if you take the two locking handles /rams and ball joint pins from the manual and put them back on the other car it'll be the same the biggest problem is the wiring i personally would just wire it up direct i'm sure there is a guide on the site somewhere. Quote Link to comment Share on other sites More sharing options...
Guest GINGExR2T Posted February 12, 2014 Share Posted February 12, 2014 . Cheers mate, that seems a nice easy job then :-) the doner car is in bit at the moment so removing the wiring or copying it shouldn't be an issue. Ginger . Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted February 12, 2014 Admin Share Posted February 12, 2014 http://www.escortcabrioletclub.co.uk/forums/index.php?/tutorials/article/10-power-roof-conversion-guide/ Quote Link to comment Share on other sites More sharing options...
badger Posted February 13, 2014 Share Posted February 13, 2014 there you go ginger thanks paul Quote Link to comment Share on other sites More sharing options...
