gingergman Posted January 30, 2014 Share Posted January 30, 2014 My amal valve clicks when the ignition is turned on, can't hear it click when engine is running tho, Problem or not? I thought possible earth? Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 8, 2014 Author Share Posted February 8, 2014 No one?? Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted February 8, 2014 Share Posted February 8, 2014 Mine used to click once when the ignition is switched on. Though only once. Assume yours is doing it a few times then maybe you have a fault. If the cars running right I wouldn't worry about it. Unless you start noticing a decrease or increase in boost that is Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 8, 2014 Author Share Posted February 8, 2014 it clicks about 4 times really fast when ignition is on then thats it, ive got another and it does the same thing. it does run iffy but not been out in it for ages to see of anything else i have done has sorted it. it ran perfect in donor car, dont recall it clicking then. Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 8, 2014 Author Share Posted February 8, 2014 is it worth fucking it off for a bleed valve? wont need any wiring then?? Quote Link to comment Share on other sites More sharing options...
Guest GINGExR2T Posted February 8, 2014 Share Posted February 8, 2014 . Seen this before on my old XR2 turbo, charged it for a spare and was ok so guessing it was faulty and seamed to drive Better with one fitted. Ginger . Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 10, 2014 Author Share Posted February 10, 2014 . Seen this before on my old XR2 turbo, charged it for a spare and was ok so guessing it was faulty and seamed to drive Better with one fitted. Ginger . I don't understand your post mate? Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted February 10, 2014 Share Posted February 10, 2014 I'd keep it as it is. I don't know the spec your running so I would suggest getting it setup. If you switch to a bleed valve you'll change the boost characteristics. You then run the risk of having areas in the map that are lean which will destroy the engine. If it's chipped already it'll only cost £200 for a setup which will make sure what's working and AFR's are as they should be. No other way of checking this. Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 10, 2014 Author Share Posted February 10, 2014 thanks for the reply mate, yeah i was gunna get it set up at jamsport, il see how its running when i get it out in april. a rolling road set up was about 200 quid they told me. Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted February 11, 2014 Share Posted February 11, 2014 I took mine to jam-sport they know these cars inside out. Mine had a poorly adjusted actuator, boost leak on dump valve. And fueling was too rich. They sorted the faults and set it up for £220. Without the rolling road you would never have seen the problems Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 12, 2014 Author Share Posted February 12, 2014 its not bad price wise concedering it will make engine run sweet, and it makes a awesome video lol. if it runs like a turd il be taking it there, not like its far from me! cheers mate! Quote Link to comment Share on other sites More sharing options...
