Guest dajafu2002 Posted January 27, 2014 Share Posted January 27, 2014 I just about to buy a good solid Escort 1987 cabriolet as a project. The plan is to fit a RST engine and gear. The car is not the EFI or MFI but the older version with what looks like a carb. My questions are as follows. Will the wiring be a nightmare? or will it simply be changingng the looms over, RST ECU and sensors etc? Will the standard gearbox and drive shafts etc cope with the extra power? I pan on upgrading the brakes and suspension. What other problems am I likley to encounter with this conversion? I am a keen mechaninc so I will be doing most / all of the work myself. I have not yet committed to buy the car yet! Quote Link to comment Share on other sites More sharing options...
badger Posted January 27, 2014 Share Posted January 27, 2014 right the best way is to change the whole loom /ecu as one also the drive train for both are the same apart from rs turbo's have a lsd but if you buy a rst donor car you car just transfer what you like i'd upgrade brakes and engine/gearbox mounts as well. Quote Link to comment Share on other sites More sharing options...
Guest dajafu2002 Posted January 27, 2014 Share Posted January 27, 2014 Ok that's great so change the whole loom? I have never changed one over before. Thanks Quote Link to comment Share on other sites More sharing options...
