Ford Escort Convertible Mk4 1.6 Xr3I 1989 Greg
Guest callum
Guest callum
Enginebay Wiring Loom Plugs And Bullet Connections 1989 Greg Mk4 1.6 Xr3I
the problem i have is that my engine wiring loom has been disconnected from the engine bay from all of the plug connections and bullet connectors in the engine bay. i have put the wiring loom back into what i think is the right position and have managed to find where most of the plug connections go but i have 1 where i dont know where it goes. i have 4 or 5 bullet connectors which i have been told are for the sensors but im not sure. the headlamps and indicators are off the car at the moment so the wires i have placed where i think they should be should be ok. does any one have pictures of there engine bay wiring loom from the black fuse box to all of the engine bay covering the starter motor alternator headlamps connections indicators connections battery coil pack. hopefuly someone can help me out. thank you.
Guest callum
your better off taking pics of wires where you dont know what there for and posting them up. connectors should only fit the sensors there supposed for so if you got them connected there be right
thank you i will go and take some pics in a bit and post them up.
