Question On Roof Not Opening
Guest poslla
hi got a quick question
my roof will not open by the switch I have checked my pump for the 2 green relays which it does not have it has the silver fuse so is this normal also when I press the switch theres a clicking by the fuse box so im guessing that's chuffed so can anyone tell me which relay it is please
cheers
paul
oh its mk 5
so it doesnt have the green relays? if it doesnt then thats why! and the silver fuse is a thermal switch and thats part of the pump wiring etc
Are you trying the switch with the ignition fully on? try it with the key only turned once etc
Guest Royv412
There are relays in the front drivers floor well, if you search in the tutorial section under Mk5 roof switch bypassing the ignition, I know it's not what you were looking for but it shows a picture of the relays and will give you an idea of what you're looking for
Roy
  • 3 months later...
Guest baz9707
Flaming heck I have the same problem with just getting a click changed switch and checked connection in the boot. Poss you get it sorted. Or are there any other suggestions.
Cheers baz
Besides the relays there is also a quite expensive box of kit preventing you trying to raise or lower the roof when the vehicle is in motion (ie when the engine is running) and if this fails, as it did on mine it is better just to get a competant vehicle electrician to bypass it. When this was done to mine he made it so that it could be raised when the engine was running, which is much better if you use your car with the roof down in the winter, as I do. Before it used to flatten the battery if you were not careful. Now of course I do have to make sure that I am stationary before I try raising or lowering it!
  • 3 weeks later...
Guest Terry Pollard
Hi It's been interesting reading all your thoughts on this matter, I am in the same postion with mine, just when I thought mine was the only one not working as it should.
Does any one know if the Mk5 ever had spot lights fitted?
Regards Terry
  • 1 month later...
