Mk4 Upgrades - Air Filter And Strut Brace
Guest Tony8020
Guest Tony8020
Guys, I have just purchased a strut brace and air filter for my MK4 cabby.
She is with the garage next Friday for her clutch change and I was wondering if I should just let them fit the strut brace and air filter for me? i.e. are both jobs ones that I can do with a spanner set and a bit of patience?
Also, how do I tell if mine is MFI or EFI?
Cheers
EFi
will be stamped on the inlet Manifold
you'll also hav a coil pack & edis module
ECU will be behind the center console
MFi
will have a distributor & a coil on the inner wing
plus you'll hav a fuel metering unit below the Air filter
& the fuel pump will be under the car by the tank
  • 4 months later...
