Guest kenny stag Posted August 9, 2013 Share Posted August 9, 2013 Hi all you nice chaps, Can you please tell me how to get mildew of the inside of the roof. Also what is the best thing to clean the outside of the roof with. Maybe someone can tell me what tyre pressure oes in the 15" low profiles. Your help would be appriciated. Thanks in advance Kenny Quote Link to comment Share on other sites More sharing options...
welshlad Posted August 9, 2013 Share Posted August 9, 2013 Tyre pressure should be written on the tyres, i would use household mildew remover for the insides as its only vinyl type material Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted August 9, 2013 Admin Share Posted August 9, 2013 hi kenny for the cleaning i would recommend g101 its very good all round cleaner and you can dilute to the strength you require do a search through ebay or google ( autosmart g101) ollie Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted August 9, 2013 Share Posted August 9, 2013 28psi on the tyres. The sidewall only reads the max psi reading for use on the tyre. This will be way to high for every vehical Quote Link to comment Share on other sites More sharing options...
