Guest Dave Munton Posted August 8, 2013 Share Posted August 8, 2013 hi all hope all is well im having 1 last go before it comes off the road for a new engine lol i have a 1990 mk4 escort xr3i that has a constant misfire and its really pissing me off so any help would be great thanks things that have been changed coil pack leads plugs its had new oil and filter please help Quote Link to comment Share on other sites More sharing options...
Guest IanA Posted August 8, 2013 Share Posted August 8, 2013 My suggestion, having just saved myself the cost of a lambda sensor by doing it- unplug and reconnect every plug & socket you can find under the bonnet. Quote Link to comment Share on other sites More sharing options...
Guest Dave Munton Posted August 8, 2013 Share Posted August 8, 2013 have done that mate its bloody pissing me off lol Quote Link to comment Share on other sites More sharing options...
Paul Grainger Posted August 18, 2013 Share Posted August 18, 2013 What cylinder is it? With the engine running, pull off each lead In turn with a pair of plastic pliers to avoid shocks. see which one doesn't make a difference. Swap the plugs around and se if the misfire moves to a different cylinder, if it does then it is the plugs. If not, then check the compressions. If all is ok then you could be looking at an injector. Good luck. Quote Link to comment Share on other sites More sharing options...
