gingergman Posted August 2, 2013 Share Posted August 2, 2013 im looking to get a boost gauge, dunno whats best psi or bar? and are ones like this actually any good or just cheap ebay crap? http://www.ebay.co.uk/itm/S3-52mm-Turbo-Boost-gauge-psi-Sierra-Escort-Fiesta-RS-Cosworth-RS500-Focus-/171091778565?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27d5dd5c05 Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted August 3, 2013 Share Posted August 3, 2013 Depends on how accurate a reading you want. Psi spread out is better . If its rs turbo you'll have a over boost cut out if you looking at around a 200 bhp spec and chip. After that they remove the over boost cut so its more essential to run a boost gauge. Only thing to be aware of is as your spec increases and boost. Cheap parts can start to leak on gauges causing fuelling issues and extra load on the turbo Quote Link to comment Share on other sites More sharing options...
gingergman Posted August 9, 2013 Author Share Posted August 9, 2013 thanks for the advice Quote Link to comment Share on other sites More sharing options...
