Skittles80 Posted May 28, 2013 Share Posted May 28, 2013 Sorted one electric problem now have another every time you put the ignition on the cooling van comes on but with the engine running it is not on it is now causing the battery to go flat any ideas thanx mark Quote Link to comment Share on other sites More sharing options...
Guest taz1787 Posted May 31, 2013 Share Posted May 31, 2013 check wiring sounds as if wired wrongly ?? but could also be fan temp sensor that's faulty Quote Link to comment Share on other sites More sharing options...
