Guest webby48 Posted March 30, 2013 Share Posted March 30, 2013 hello, hope u can help! cabriolet 1995, next to hand brake theres a button ,red square with an arrow,whats it for? plus my roof will not come down via the button? i know about windows etc i have by passed to the motor alone and got it to work,could it just be a fuse and if so which one and where? ta Link to comment Share on other sites More sharing options...
Guest Jason Rawlings Posted March 30, 2013 Share Posted March 30, 2013 I have the same query about the mystery button, and also the electric hood is not working (motor isn't even trying). The mystery button never seemed to to do anything, but now that the hood isn't working, the button illuminates when released. Can anybody help us with this?? Link to comment Share on other sites More sharing options...
Guest Jain0 Posted March 30, 2013 Share Posted March 30, 2013 The red button is the power cut off switch for the rear windows, recommended to use if children in the car. Fuse No 22 (30amp) is the power operated windows/sunroof. Hope this helps Link to comment Share on other sites More sharing options...
Guest Jain0 Posted March 30, 2013 Share Posted March 30, 2013 Jason, Have you checked the hydraulic fluid level in the motor? but sounds like the motor could have packed up or you may have a bad earth somewhere. Link to comment Share on other sites More sharing options...
Vincygav Posted March 30, 2013 Share Posted March 30, 2013 Or check the relays also. Link to comment Share on other sites More sharing options...
