Guest tazanddave Posted February 9, 2013 Share Posted February 9, 2013 I have a 1990 Efi cabby with a fuel gauge that doesn,t work. Its always on the very bottom. A friend suggested checking the earth under the back seat. .(hope its brown wire under the seat behind drivers seat screwed into bodywork?) This is fine as are the connections on the back of the dial itself. He also suggested pos replacing the sender unit and fuel tank. Are these available new or would i need to get 1 from a breaking Efi? Sorry folks,bit new to all this,lol. Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 10, 2013 Share Posted February 10, 2013 The fuel tanks for the EFI are serious dollar to get new, you won't get a new sender, would have to be second hand. Quote Link to comment Share on other sites More sharing options...
Guest tazanddave Posted February 14, 2013 Share Posted February 14, 2013 Do i need to get both the sender and fuel tank though ginger? Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 14, 2013 Share Posted February 14, 2013 No just the sender if that's all your after, make sure its from an EFI though, as there different. If you did go down this route its a tank off job. Quote Link to comment Share on other sites More sharing options...
