Guest martinkettering Posted January 24, 2013 Share Posted January 24, 2013 so today ive had dash apart to fix blower motor problem,question is now,the car doesnt have a heated screen,and only rear demister button,upon removal,ive found the plug for heated front screen,so does this mean that there should be wiring near screen for it?now the thing is if there is once ive looked for them,im having screen changed due to large crack in it,should glass company fit a heated or standard screen,or just call them and see what they will fit... Quote Link to comment Share on other sites More sharing options...
sifitz Posted January 24, 2013 Share Posted January 24, 2013 hi yes the ghia has the wiring for the heated front screen but it will need the wiring in the engine bay and the extra fuse that fitted next to the battery and if you get the engine bay it connects to the wiring loom to a muti plug on the drivers side engine bay just below the windscreen next to the abs pump (if fitted) and this engine bay loom also has the connetors for the windscreen Quote Link to comment Share on other sites More sharing options...
Guest martinkettering Posted January 24, 2013 Share Posted January 24, 2013 cheers mate,will have a look 2moro,for a ghia x spec,it doesnt have abs or heated front screen,or leather interior Quote Link to comment Share on other sites More sharing options...
