Guest ben smith Posted December 23, 2012 Share Posted December 23, 2012 Hi not sure Wots happening here but ... Side lights and dipped beam work perfect ... But when sidelights are on the main beam won't flash when I pull the stalk ... On dipped beam when I pull the stalk only drives side light comes on and when I push the stalk in to permanent main beam the passenger side light goes out completely... Also noticed the main beam light in the dash don't come on either now Quote Link to comment Share on other sites More sharing options...
RScab Posted December 23, 2012 Share Posted December 23, 2012 Sounds like the light stork is faulty Quote Link to comment Share on other sites More sharing options...
Guest ben smith Posted December 28, 2012 Share Posted December 28, 2012 fixed it turned out to be where the live joins the live for the other side it wasnt connecting properly so just re did the connection using a new connector and th trimming the wire back for some fresh wire and reconnected it all Quote Link to comment Share on other sites More sharing options...
Guest barry1974 Posted February 15, 2015 Share Posted February 15, 2015 Ben, please can you contact me to advise more details as I ha e the exact. Same issue that you had. Quote Link to comment Share on other sites More sharing options...
