Removing Heated Windscreen... How?
Guest Aaron James Sadler
Hi All,
How do i remove the mk4 windscreen, without breaking both the rubbers and windscreen, it's heated so if that can work after as well that would be great lol... there is a bit of rot in the passengers bottom corner of the frame that needs sorting :sad:
You gotta have patients for this, if the rubber is getting perished cut it and be on the safe side!
Use a wide screw driver or similar to tuck the rubber under from the inside slowly a bit at a time, should get there slowly,
But the amount of times I've tried and its cracked lol
