Escort Wouldn`t Start When Warm Or Hot
Guest nellyboy
Guest nellyboy
hi had a problem with my 1.8 16v zetec starting fine when cold but struggling to start when warm or
hot..thought id post how i fixed it to give some guidance if anyone has the same issue..
firstly i checked with a local parts factor to see if my coolant temperature sensor controlled
the guage only or was part of the ECU..
from my registration they informed me it was the one that was connected to the ECU..
£15 pound and 15 minutes later the job was done...(screwed in passenger side of block) but if struggling im sure the motor factors will point out its location for free on purchase..
plus this giving a view to compatability..
my lovely cab now starts everytime no matter the engine temperature..
this may not be the case for your vehicle but its a starting point and fixed mine..
Guest El87cabi
A good job well done dude, those zetec's have a fair few hard to track down faults and this is 1 of them, i'm sure your post will prove most useful :smile:
All the best, el
  • 3 weeks later...
  • 9 months later...
My mfi cvh xr3i hates starting when warm but when hot u have turn key so fan stsys on for bit then itk start sny ideas
do the starter turn over when this happens??
