Guest martinkettering Posted October 25, 2012 Share Posted October 25, 2012 Took the cabby for its 1st decent run last night and several problems came to light,when you accelerate hard it pulls to the right but once of the gas and cruising its fine,also it felt like the being on a rough sea,opposite corners going up and down,but once again at a cruising speed it was fine,but then started doing it over a certain speed,its had both wishbones replaced and 1 n/s/f shock replaced on its last mot in november,ive had a look and everything seems ok tho,any thoughts ???? Quote Link to comment Share on other sites More sharing options...
gingergman Posted October 26, 2012 Share Posted October 26, 2012 are the tyres wearing evenly? Quote Link to comment Share on other sites More sharing options...
Guest ben smith Posted October 26, 2012 Share Posted October 26, 2012 last i heard for things like this is it could be a tracking rod out from replacing the shock but shocks should always be replaced in pairs cos it can have that effect and can lead to bigger problems Quote Link to comment Share on other sites More sharing options...
Guest martinkettering Posted October 26, 2012 Share Posted October 26, 2012 im going to get new shocks and springs and pop it over to wim's in mk for a full geo check and then see what else needs doing,thanks for the replies Quote Link to comment Share on other sites More sharing options...
Guest martinkettering Posted October 29, 2012 Share Posted October 29, 2012 just a quick update,it was the nearside wishbone rear bush that has gone,so just waiting for new 1's to arrive Quote Link to comment Share on other sites More sharing options...
