Guest Paddy Posted June 6, 2012 Share Posted June 6, 2012 I've put a 2.0 black top zetec in my cab, all fitted in & running...ish, but I'm stumped on 1 issue. I'm using an inlet manifold like in the picture below (not my actual manifold). The pipe circled in red is where I's confused. If I leave this pipe open the engine ticks over at about 1400rpm. I'm assuming it's supposed to join the crankcase breather system somewhere so I tried joining it direct to the pipe from the oil separator - engine won't run. If I make a 3 way connection including the breather pipe from the back of the cam cover it'll run, but ticks over at about 600rpm. What have other people done? Most pics I see of zetecs fitted in earlier cars have a small filter fitted to the cam cover breather so I'm guessing that ain't being used to feed this pipe. The only other option I can think of is to join it into the inlet system between the filter & the throttle body, which I haven't tried mainly because I ain't got the pipe for that yet but partly cos wouldn't that be the same (restriction wise) as leaving it open? Paddy Quote Link to comment Share on other sites More sharing options...
badger Posted June 6, 2012 Share Posted June 6, 2012 mine in attached to the oil seperator only and it runs fine Quote Link to comment Share on other sites More sharing options...
Guest Paddy Posted June 6, 2012 Share Posted June 6, 2012 That helps thanks, tho that suggests my problem is elsewhere . Back to the drawing board I guess. One strange thing I did come across on extraefi was they reckoned on there the (2 wire) idle control valve should have a 12v supply to it & a return feed to the megasquirt ecu, but my diagram shows the 1 wire from the icv to the ecu but the other wire going to earth. I think the Ford ecu had it wired this way as well. I may try running a wire direct from the ecu to the icv rather than using the old loom, as this solved me problems with the inlet air temp sensor. I have noticed on the megatune program the FIdle button btm left of screen keeps flickering on & off. Don't look like I'll be going to the beach in the cab this weekend Paddy Quote Link to comment Share on other sites More sharing options...
