Guest Rustler Posted May 30, 2012 Share Posted May 30, 2012 Hi.... I'm still searching for a set of alloy wheels and tyres.....".AT THE RIGHT PRICE"......... Have located some TEAM DYNAMIC 1.2's........16" x 7J ....with 195/45/R16 tyres...our existing originals are 14" x 6J & 185/60/R14s assuming that the ET on the Team Dynamics is the same as the originals ie ET35....... what are the ..Fore & Against .. arguments on going up to 7J from 6J ?..........................Any ideas please........Thanks............Rustler........."The Oldest Cabbier"... Link to comment Share on other sites More sharing options...
Guest Alanman Posted May 30, 2012 Share Posted May 30, 2012 From memory, a 7j will just poke a little more than the 6j if they both the same ET. But it'll but a few mm, so not enought to worry about. And obviously a wider tire will give a better footprint and better grip and handling. So all pro's One bit of advice I can give you. I'd check the price of the 16" tires if you've not already done so. You'll find that going up to 17s will give you a lot more choice on tyres. 16s are not so common and can end up costing quite a bit more. Link to comment Share on other sites More sharing options...
Guest Rustler Posted June 3, 2012 Share Posted June 3, 2012 Thanks Alanman for your info..... Yes, I had noted that 16" tyres were a lot dearer than 15" & 17" tyres.......But on these wheels the tyres were brand new.......HOWEVER..... When I asked the bloke to check the ET# .....he came back with the answer. Sorry M8, but the ET's 48 ....so I,ve blown them out...."BACK TO EBAY" ..............Rustler ............."The Oldest Cabbier"........... Link to comment Share on other sites More sharing options...
