Guest sakuv Posted February 26, 2012 Share Posted February 26, 2012 I've just bought a 1997 Escort and the roof does not work, when the switch ispressed so relays yes "rattle" or work? pump is running when you tried itdirectly from the battery, but not in the car closed. Is there anything in anycircuit breakers, or what could be the problem???? thank you very much saku by finland Quote Link to comment Share on other sites More sharing options...
badger Posted February 26, 2012 Share Posted February 26, 2012 I'vejust bought a1997Escortand theroofdoes not work,whenthe switch ispressedsorelaysyes"rattle" orwork?pumpis runningwhen youtried itdirectlyfrom the battery,butnotin the carclosed.Isthere anythingin anycircuit breakers,orwhatcouldbe theproblem???? thank youverymuch saku by finland the roof will only work when the ignition is in position 1 (so without the engine running) so try that first ?????? Quote Link to comment Share on other sites More sharing options...
Guest sakuv Posted February 26, 2012 Share Posted February 26, 2012 thanks, will try as soon as tomorrow, or the engine must be turned off?matter whether the electric windows up or down? whether others in the carbreakers who could be affected? thank you Quote Link to comment Share on other sites More sharing options...
Guest moongem288 Posted February 28, 2012 Share Posted February 28, 2012 (edited) When I got my 1997 escort my roof didnt work atall I checked all the fuses attached to the hydrolic pump in the boot and found a thermostat fuse that comes off what looks like the green/yellow earth wire was the problem I gave it a shake and heard the rattle. I ordered a new one and works perfect now. Edited February 28, 2012 by moongem288 Quote Link to comment Share on other sites More sharing options...
Guest sakuv Posted March 6, 2012 Share Posted March 6, 2012 thank you moongem288, I had a broken thermostat fuse even though the gauge shows it to be intact. thank you Quote Link to comment Share on other sites More sharing options...
